TGood to know it works.
My rears are actually going hydraulic to match the front.
The fronts have been dogged by twitching to the left under first hard braking (after the first stab they're alright for a while, if frequently used but it doesn't engender confidence). I reckon this is the front cylinder on the right hand side being a bit lazy (seems so under test on axle stands.). It'll be replaced. I also suspect that it's exacerbated by strong brakes at the front only, making the car more nervous. And the diff was leaking through a gasket so I needed to address the axle anyway.
Charles
Charles
