Bore honing
HI Andy,
Normally around .001  is left to the hone a lot depends on how fine the boring marks are because they must be removed,
the reason for the use of parallel adjusting hones is to keep the bore parallel  which is not possible with Deglazing hones.
I have done a lot of Rebores and there is no way around doing the job properly if you are going to the trouble of boring and you want the best fit for rings and pistons
Cheers Colin
NZ
Bore honing - by Andy Bennett - 30-05-2018, 08:54 PM
RE: Bore honing - by Colin Reed - 30-05-2018, 09:08 PM
RE: Bore honing - by Stuart Giles - 30-05-2018, 09:12 PM
RE: Bore honing - by Andy Bennett - 31-05-2018, 08:18 AM
RE: Bore honing - by Bob Culver - 31-05-2018, 09:02 AM
RE: Bore honing - by Andy Bennett - 31-05-2018, 08:29 PM
RE: Bore honing - by Colin Reed - 31-05-2018, 08:58 PM
RE: Bore honing - by Steve Jones - 31-05-2018, 09:01 PM
RE: Bore honing - by Charles P - 31-05-2018, 11:08 PM
RE: Bore honing - by Stuart Giles - 01-06-2018, 12:18 AM
RE: Bore honing - by Bob Culver - 01-06-2018, 01:32 AM
RE: Bore honing - by Colin Reed - 01-06-2018, 02:13 AM
RE: Bore honing - by Andy Bennett - 03-06-2018, 09:00 PM
