Bore honing
I use about 2 seconds down and 2 seconds up doing bores with a Flex Hone. This is usually with a 240 grit hone (blue blob on the tip). It would be a smidge quicker on each pass with a 180 grit hone (red blob on the hone's tip) I've never bothered to try and get a diamond pattern, just a uniform finish. Any light lubricant should work OK - I use ISO 32 hydraulic oil because I have gallons of it here.
Bore honing - by Andy Bennett - 30-05-2018, 08:54 PM
RE: Bore honing - by Colin Reed - 30-05-2018, 09:08 PM
RE: Bore honing - by Stuart Giles - 30-05-2018, 09:12 PM
RE: Bore honing - by Andy Bennett - 31-05-2018, 08:18 AM
RE: Bore honing - by Bob Culver - 31-05-2018, 09:02 AM
RE: Bore honing - by Andy Bennett - 31-05-2018, 08:29 PM
RE: Bore honing - by Colin Reed - 31-05-2018, 08:58 PM
RE: Bore honing - by Steve Jones - 31-05-2018, 09:01 PM
RE: Bore honing - by Charles P - 31-05-2018, 11:08 PM
RE: Bore honing - by Stuart Giles - 01-06-2018, 12:18 AM
RE: Bore honing - by Bob Culver - 01-06-2018, 01:32 AM
RE: Bore honing - by Colin Reed - 01-06-2018, 02:13 AM
RE: Bore honing - by Andy Bennett - 03-06-2018, 09:00 PM
