Clutch toggle levers
(29-05-2018, 09:27 AM)Terrytuned Wrote: 3psd flywheel with toggle springs fitted
Thats the way to do it Terry, without the mousetrap springs the toggle levers will fly out to contact the thrust bearing so it will always be spinning. Do not test run an engine on a stand without mousetrap springs and gearbox in place the toggle levers will attack the bell housing studs.
I use a spring from the oiler to a modified oiler cover plate to retract the thrust bearing
I know the gearbox top is reversed, the unit is on it's transportation/storage stand and it takes up less room that way round.
Clutch toggle levers - by John Mims - 28-05-2018, 03:45 PM
RE: Clutch toggle levers - by Charles P - 28-05-2018, 03:54 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 04:04 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 06:57 PM
RE: Clutch toggle levers - by Charles P - 28-05-2018, 08:25 PM
RE: Clutch toggle levers - by Tony Press - 29-05-2018, 08:29 AM
RE: Clutch toggle levers - by Charles P - 29-05-2018, 09:24 AM
RE: Clutch toggle levers - by bob46320 - 28-05-2018, 04:34 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 28-05-2018, 05:00 PM
RE: Clutch toggle levers - by Terrytuned - 28-05-2018, 07:22 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 08:36 PM
RE: Clutch toggle levers - by Terrytuned - 29-05-2018, 09:27 AM
RE: Clutch toggle levers - by Dave Mann - 29-05-2018, 08:34 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:31 AM
RE: Clutch toggle levers - by Terrytuned - 29-05-2018, 09:54 AM
RE: Clutch toggle levers - by Robert Leigh - 29-05-2018, 11:26 AM
RE: Clutch toggle levers - by John Mims - 29-05-2018, 11:58 AM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:58 AM
RE: Clutch toggle levers - by Steve Jones - 29-05-2018, 10:51 AM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 02:40 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:15 PM
RE: Clutch toggle levers - by Dave Mann - 30-05-2018, 05:56 PM
RE: Clutch toggle levers - by Terrytuned - 30-05-2018, 07:23 PM
RE: Clutch toggle levers - by Stuart Giles - 01-06-2018, 12:27 AM
RE: Ruairidh Ring. - by redruthman07@gmail.com - 12-05-2020, 09:20 AM
RE: Clutch toggle levers - by Dave Mann - 12-05-2020, 09:24 PM
RE: Clutch toggle levers - by JonE - 26-02-2021, 10:12 PM
RE: Clutch toggle levers - by Dave Mann - 27-02-2021, 10:28 AM
