Clutch toggle levers
(28-05-2018, 03:54 PM)Charles P Wrote: I use late type levers, with the hammerhead, and a four speed release bearing on a 3 speed engine and gear box. No problems. And no, I don't bother with mousetrap springs.
I know of a number of other people with the same set up. Much easier on the release bearing because it's not always revolving.
Charles
My memory letting me down again! When I used a 3-speed engine and 4-speed release bearing, I was fitting a 4-speed gearbox. With the RN it's 3-speed, of course.
I've found a 4-speed release bearing, but on the 3-speed gearbox, the flange is missing for the circlip  that holds the retaining/return spring on the release bearing. Do I just fit it without the return spring?
John
Clutch toggle levers - by John Mims - 28-05-2018, 03:45 PM
RE: Clutch toggle levers - by Charles P - 28-05-2018, 03:54 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 04:04 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 06:57 PM
RE: Clutch toggle levers - by Charles P - 28-05-2018, 08:25 PM
RE: Clutch toggle levers - by Tony Press - 29-05-2018, 08:29 AM
RE: Clutch toggle levers - by Charles P - 29-05-2018, 09:24 AM
RE: Clutch toggle levers - by bob46320 - 28-05-2018, 04:34 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 28-05-2018, 05:00 PM
RE: Clutch toggle levers - by Terrytuned - 28-05-2018, 07:22 PM
RE: Clutch toggle levers - by John Mims - 28-05-2018, 08:36 PM
RE: Clutch toggle levers - by Terrytuned - 29-05-2018, 09:27 AM
RE: Clutch toggle levers - by Dave Mann - 29-05-2018, 08:34 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:31 AM
RE: Clutch toggle levers - by Terrytuned - 29-05-2018, 09:54 AM
RE: Clutch toggle levers - by Robert Leigh - 29-05-2018, 11:26 AM
RE: Clutch toggle levers - by John Mims - 29-05-2018, 11:58 AM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:58 AM
RE: Clutch toggle levers - by Steve Jones - 29-05-2018, 10:51 AM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 02:40 PM
RE: Clutch toggle levers - by Ruairidh Dunford - 29-05-2018, 09:15 PM
RE: Clutch toggle levers - by Dave Mann - 30-05-2018, 05:56 PM
RE: Clutch toggle levers - by Terrytuned - 30-05-2018, 07:23 PM
RE: Clutch toggle levers - by Stuart Giles - 01-06-2018, 12:27 AM
RE: Ruairidh Ring. - by redruthman07@gmail.com - 12-05-2020, 09:20 AM
RE: Clutch toggle levers - by Dave Mann - 12-05-2020, 09:24 PM
RE: Clutch toggle levers - by JonE - 26-02-2021, 10:12 PM
RE: Clutch toggle levers - by Dave Mann - 27-02-2021, 10:28 AM
