Rec counter drive from dynamo
Maybe you'll need a completely new cable with a connector already attached. Even then, some fiddling with the attachment point and the various dimensions at the distributor end will be required - it's always a puzzle when trying to get non-standard parts to work. The spade connector system looks to be a far more robust solution than a cable with its end ground square and fitting into a square socket.
Rec counter drive from dynamo - by Erich - 05-05-2025, 01:45 AM
RE: Rec counter drive from dynamo - by Lowespeed - 05-05-2025, 11:25 AM
RE: Rec counter drive from dynamo - by Erich - 05-05-2025, 02:22 PM
RE: Rec counter drive from dynamo - by Erich - 05-05-2025, 07:35 PM
RE: Rec counter drive from dynamo - by Tony Griffiths - Yesterday, 02:43 PM
