Yesterday, 02:30 PM
(This post was last modified: Yesterday, 02:36 PM by Tony Griffiths.)
(06-05-2025, 01:06 PM)JohnD Wrote: Thank youYou may find this article helpful; it tells you about fitting a 'transil' (in effect a capacitor) across the points to stop them arcing and so extend their life.
I looked at that option lastnight, but wasnt convinced it would be easy to access should it need any maintinence.
https://ttypes.org/extend-the-life-of-yo...a-transil/
I'm unsure if new 6-volt pumps can be ordered with one already fitted (the plastic end cap has a cylindrical bulge if they do). https://sucarb.co.uk/su-fuel-pumps-spare...-volt.html
https://sucarb.co.uk/su-fuel-pumps-spare...-kits.html
The SU website looks to have been designed by a 12-year-old on acid. Looks modern and clean, but is challenging to navigate. The menu system is hopeless, and the search is useless - put in "6-volt fuel pump" and you get almost anything but. Finally, I phoned them about a different enquiry and was given excellent help: 01722-412-500
