  • 1 Vote(s) - 2 Average
Smiths (magmo) speedometer repair.
Ivor,
Had a look through the site but did not spot any suitable gears. Will have a longer look tonight as I may have missed something.
Tony,
The teeth on the gear are mostly missing, but I suspect a 20 tooth 32 DP gear is going to be pretty close.
Have taken the gear off the shaft and it has a splines so this would cause problems re fitting.
Might just order some 20 tooth gears on spec and try filing splines.
Managed to get one fully working speedometer now. Did suspect the mile counter was the cause of the ruined gear
but left it driven by an old battery drill for several hours and seems to count up without sticking.
So basically just have to get the mile counter drive sorted and I will have a spare unit should the fitted one ever fail.
Also (for fun) found an APP that works on my Iphone and Ipad that does both speed and milage, so if all else fails !.
Martin.
Smiths (magmo) speedometer repair. - by GM6VXB - 21-04-2025, 07:50 PM
RE: Smiths (magmo) speedometer repair. - by GM6VXB - 22-04-2025, 02:31 PM
