08-04-2025, 09:31 AM
I have a Special with a remote change, mounted to the prop shaft tunnel. To select reverse, I need to lean forward and lift the selector at the gearbox end, which means I have to behave somewhat like a contortionist. I'm wondering how other people get around having to lift the remote linkage to select reverse. I'll most likely need to re-engineer my setup to make it work. I can post a photo tomorrow, if that helps.
Cheers, Geoffrey
