17-03-2025, 06:41 PM
(12-03-2025, 03:14 PM)`Gordonhbm Wrote: I am greatly enjoying this topic! Since the plate is anchoring the spring to the axle beam then to accommodate spring length change on suspension movement there has to be some play in the shackle pin assembly?
There doesn't need to be accommodation for movement at both ends of the spring, one end will do. The plate is only fitted at one end.
