15-03-2025, 12:44 PM
If it's a Gould Ulster it will most likely have been improvised by whoever built it, and you may have to do the same.
Unless you can ID the cable you have by means of a part number, you'll have to find something which can be made to fit.
Inners and outers can both be shortened if you find something close.
There are firms which will make cables to order at a price, otherwise it's a question of rummaging through second hand cables or finding something on eBay with suitable dimensions.
Is your cable broken? End fittings can often be re-soldered or replaced with screw clamp fittings.
