  • 1 Vote(s) - 3 Average
New member hello & APD rebuild
#51
Hi
Having recently done an engine rebuild, here are my top tips:
+1 for slipper pistons, noticeably reduced friction and slightly lighter
+1 for balancing rods at both ends
I used cap head 12.9 grade screws for the little ends, with red loctite. Gudgeon pins must be free in cold pistons, a little "working" may be needed with thin lubricant to take off microscopic high spots.
+1 for at least statically balancing the heavy flywheel / clutch. I didn't bother with the crank.
I used new standard valve springs, which seem fine to 4500 RPM but I rarely go above 4000.
+1 for silicone base gasket (and sump gasket)
A high compression head will increase top end power, but won't be as smooth with only 2 bearings. It can be left as a later mod if desired.
Ignition timing is reliant on multiple pairs of gears all with backlash. Minimise this if you can, even dynamo end float can cause timing scatter.
I didn't modify the oil system, I just use modern oil which is vastly better than anything in the 1930's and change it regularly.
I did the front cam bush mod with a cap head screw tapped into the bush to hold it tight. I didn't add O rings as it was snug in the crankcase.
New member hello & APD rebuild - by Goldnrust - 28-11-2024, 05:32 PM
RE: New member hello & APD rebuild - by Goldnrust - 29-11-2024, 05:01 PM
RE: New member hello & APD rebuild - by Goldnrust - 04-12-2024, 01:33 PM
RE: New member hello & APD rebuild - by bob46320 - 05-12-2024, 09:32 AM
RE: New member hello & APD rebuild - by Goldnrust - 06-12-2024, 03:52 PM
RE: New member hello & APD rebuild - by Goldnrust - 16-12-2024, 11:59 PM
RE: New member hello & APD rebuild - by Goldnrust - 03-01-2025, 12:06 AM
RE: New member hello & APD rebuild - by Steve kay - 03-01-2025, 08:45 AM
RE: New member hello & APD rebuild - by Dave Mann - 03-01-2025, 03:34 PM
RE: New member hello & APD rebuild - by Goldnrust - 03-01-2025, 05:43 PM
RE: New member hello & APD rebuild - by Goldnrust - 07-01-2025, 01:38 PM
RE: New member hello & APD rebuild - by Goldnrust - 03-02-2025, 11:19 PM
RE: New member hello & APD rebuild - by Dave Mann - 04-02-2025, 04:00 PM
RE: New member hello & APD rebuild - by Goldnrust - 04-02-2025, 10:08 PM
RE: New member hello & APD rebuild - by Goldnrust - 20-02-2025, 12:16 AM
RE: New member hello & APD rebuild - by Goldnrust - 21-02-2025, 10:40 PM
RE: New member hello & APD rebuild - by stuartu - 22-02-2025, 07:16 AM
RE: New member hello & APD rebuild - by Goldnrust - 22-02-2025, 10:17 PM
RE: New member hello & APD rebuild - by Goldnrust - 25-02-2025, 04:12 PM
RE: New member hello & APD rebuild - by Goldnrust - 07-03-2025, 06:07 PM
RE: New member hello & APD rebuild - by Goldnrust - 07-03-2025, 11:14 PM
RE: New member hello & APD rebuild - by Alan - 08-03-2025, 01:23 PM
RE: New member hello & APD rebuild - by Goldnrust - 08-03-2025, 10:03 PM
RE: New member hello & APD rebuild - by John Cornforth - 09-03-2025, 10:35 AM
RE: New member hello & APD rebuild - by Jamie - 09-03-2025, 11:23 AM
RE: New member hello & APD rebuild - by Alan - 09-03-2025, 12:58 PM
RE: New member hello & APD rebuild - by Goldnrust - 09-03-2025, 09:50 PM
RE: New member hello & APD rebuild - by Jamie - 10-03-2025, 09:20 AM
RE: New member hello & APD rebuild - by Alan - 10-03-2025, 10:38 AM
RE: New member hello & APD rebuild - by Goldnrust - 11-03-2025, 10:11 PM
RE: New member hello & APD rebuild - by Dave Mann - 12-03-2025, 09:32 PM
RE: New member hello & APD rebuild - by GM6VXB - 13-03-2025, 08:55 AM
RE: New member hello & APD rebuild - by Dave Mann - 13-03-2025, 06:45 PM
RE: New member hello & APD rebuild - by Alan - 13-03-2025, 06:58 PM
RE: New member hello & APD rebuild - by Goldnrust - 06-05-2025, 11:26 PM
