  • 1 Vote(s) - 1 Average
Keeping it original.
Here we go again!..........or NOT as the case may be!!!
No spark.  I checked the condenser by substitution and thought I had solved the problem as I got a spark from the king lead against a head stud when I flicked the points ...but I hadn't noticed that I was opening the points to far and earthing against the body of the distributor; this produced a spark from the king lead  which I mistakenly thought was HT .....but it couldn't have been.
When I opened the points more sensibly I didn't get a spark.  I guess it is evidence of a defective HT coil winding? ...unless I have two duff condensers?. Huh Even so, I would have expected to get a spark of some sort.
I checked the rotor arm and there is no spark there so I presume that it is O.K.  There is no evidence that the distributor cap is cracked or has been arcing and the HT connections are sound and free from corrosion. There are no frayed wires and I have cleaned the points with fine sandpaper.
I am getting the correct primary coil resistance  - 1.4 ohms  (same as always ) and when I tested a wire from the CB terminal on the coil with the points open I witnessed full battery voltage, so again the primary circuit seems O.K.
With the points closed I believe the reading should be zero volts; however, I am still getting full battery voltage which sort of implies that the points are dirty...but  I have cleaned the points. Perhaps I need to do even more cleaning.? The cam is definitely opening the points...
Here's the strange bit.  I half expected the coil to be the problem as it is possibly original to the car ...but when I tried a brand new coil I still get no spark.  Not a glimmer of one.
Surely I must be going wrong somewhere?  ...or could it be the new coil is faulty.? Just to be sure, I removed the CB wire and the king lead from the distributor and then tested them to earth. By occasionally glancing the CB wire to earth I had expected a good coil to produce a spark from the king lead to earth . The result was nothing from either coil. (and yes, the ignition was switched on!)
Any ideas?
Keeping it original. - by Ray White - 01-03-2025, 11:15 PM
RE: Keeping it original. - by Tony Press - 02-03-2025, 03:39 AM
RE: Keeping it original. - by Ruairidh Dunford - 02-03-2025, 07:33 AM
RE: Keeping it original. - by stuartu - 02-03-2025, 09:41 AM
RE: Keeping it original. - by Howard Wright - 02-03-2025, 10:00 AM
RE: Keeping it original. - by Ray White - 02-03-2025, 02:27 PM
RE: Keeping it original. - by Ruairidh Dunford - 05-03-2025, 11:26 AM
RE: Keeping it original. - by Ray White - 05-03-2025, 05:41 PM
RE: Keeping it original. - by Ruairidh Dunford - 05-03-2025, 06:23 PM
RE: Keeping it original. - by Tony Griffiths - 07-03-2025, 12:47 AM
RE: Keeping it original. - by Ray White - 07-03-2025, 09:45 AM
RE: Keeping it original. - by Ray White - 08-03-2025, 10:00 PM
RE: Keeping it original. - by A G Wood - 09-03-2025, 09:45 AM
RE: Keeping it original. - by Ray White - 09-03-2025, 01:13 PM
