22-02-2025, 10:28 AM
Thank you for the replies. I have managed to remove the outer arm on the driver's side, using a jury-rigged puller. I had to file away a large burr first where someone had clouted the end of the shaft. The middle assembly is loose, so I just need to shift the passenger side arm and pull out the shaft.
Jamie.
Jamie.
