Value of Resistor in 6 Volt Cut Out
Thank you for the help with this question. I have fitted a wire-wound 2.7 ohm resistor. It was 3 but I snapped the end fitting it. I retained the Schottky diode as the smart diode that I bought looks very delicate and has no way to fix it down. The Schottky is much more robust and has a screw lug attached.
Jamie.
Value of Resistor in 6 Volt Cut Out - by Jamie - 06-02-2025, 09:06 AM
RE: Value of Resistor in 6 Volt Cut Out - by Jamie - 19-02-2025, 01:50 PM
