Sump bolts and Engine Oil
I'm not sure how you've arrived at your diagnosis Dave - you may well be right.
But before I invested energy in curing a sump joint leak, I'd clean the crankcase with brake cleaner and go for a run, and make darn sure it isn't coming from the block joint or tappet cover.
Oil has a habit of gathering around the sump regardless of which joint it emerged from.
Sump bolts and Engine Oil - by Old Dave - 13-02-2025, 05:48 PM
RE: Sump bolts and Engine Oil - by Reckless Rat - 13-02-2025, 06:13 PM
RE: Sump bolts and Engine Oil - by Alan - 13-02-2025, 06:14 PM
RE: Sump bolts and Engine Oil - by Howard Wright - 13-02-2025, 06:41 PM
RE: Sump bolts and Engine Oil - by Reckless Rat - 13-02-2025, 07:03 PM
RE: Sump bolts and Engine Oil - by Alan - 13-02-2025, 07:47 PM
RE: Sump bolts and Engine Oil - by Chris KC - 13-02-2025, 07:48 PM
RE: Sump bolts and Engine Oil - by Old Dave - 14-02-2025, 05:23 PM
RE: Sump bolts and Engine Oil - by AustinWood - 14-02-2025, 07:32 PM
RE: Sump bolts and Engine Oil - by Old Dave - 15-02-2025, 12:08 PM
RE: Sump bolts and Engine Oil - by Old Dave - 18-02-2025, 04:47 PM
