  • 1 Vote(s) - 5 Average
Crankshaft advice
Whilst those photos look horrible, I'm not quite sure what it is I'm looking at.
I was taught that if there's anything you can feel with your fingertip, it's no good.
But it wouldn't be the first time I'd touched out a slight rough patch with 1500 or 2000 grit emery and got away with it.
I can't understand how a shaft could get damaged without something showing up on the white metal or shells - unless of course the previous owner swapped knackered ones for new (without fixing the shaft).
That doesn't look like corrosion to me.
I'd guess it's a Phoenix - I could be wrong - but I have no idea what treatment they apply, that would be a question for the supplier or failing that, the manufacturer. But in terms of establishing the way forward I'd suggest taking it to a competent engine recon shop and taking their advice. They may have the means to test it, or to re-treat it if necessary. I use T&L at Elstow and generally trust their judgement on stuff like this.
Crankshaft advice - by Parazine - 13-01-2025, 04:16 PM
RE: Crankshaft advice - by Robert Leigh - 13-01-2025, 04:43 PM
RE: Crankshaft advice - by Chris KC - 13-01-2025, 05:51 PM
RE: Crankshaft advice - by Colin Reed - 13-01-2025, 08:47 PM
RE: Crankshaft advice - by Charles P - 13-01-2025, 08:52 PM
RE: Crankshaft advice - by Parazine - 14-01-2025, 11:58 AM
RE: Crankshaft advice - by Alan - 14-01-2025, 12:40 PM
RE: Crankshaft advice - by Steve Jones - 14-01-2025, 01:18 PM
RE: Crankshaft advice - by Colin Reed - 15-01-2025, 04:46 AM
RE: Crankshaft advice - by Belinni - 15-01-2025, 11:12 AM
RE: Crankshaft advice - by Bluebird7 - 15-01-2025, 08:43 PM
RE: Crankshaft advice - by Belinni - 15-01-2025, 11:27 PM
RE: Crankshaft advice - by Alan - 15-01-2025, 11:46 PM
RE: Crankshaft advice - by Bluebird7 - 16-01-2025, 11:24 AM
RE: Crankshaft advice - by Parazine - 18-01-2025, 11:30 PM
RE: Crankshaft advice - by Belinni - 18-01-2025, 11:51 PM
RE: Crankshaft advice - by David Stepney - 19-01-2025, 12:58 AM
RE: Crankshaft advice - by Belinni - 19-01-2025, 01:59 AM
RE: Crankshaft advice - by Greig Smith - 19-01-2025, 09:59 AM
RE: Crankshaft advice - by Robert Leigh - 19-01-2025, 11:21 AM
RE: Crankshaft advice - by Chris KC - 19-01-2025, 01:41 PM
RE: Crankshaft advice - by Bluebird7 - 19-01-2025, 03:07 PM
RE: Crankshaft advice - by Alan - 19-01-2025, 03:53 PM
RE: Crankshaft advice - by Parazine - 19-01-2025, 10:14 PM
RE: Crankshaft advice - by Bluebird7 - 19-01-2025, 11:22 PM
