08-01-2025, 09:26 PM
Hi Erich
Did you grind back the stop on the offside of the gearbox face plate? There is a semi circular protrusion on the original face plate that prevents the clutch levers from moving back. This stop needs to be removed if using the four speed release bearing.
Hope this helps?
Hope this helps?
