Ulster Rep Rebuild - Gearbox release bearing pressing on clutch arms
Check that the clutch driven plate is able to contact the flywheel surface. It Could be that the flywheel nut lockwasher isn't fouling the domed inner ring of the driven plate. If the diameter of that washer is greater than the maximum diameter of the nut, i.e.greater than the diameter across opposite points then the washer will interfere with the clutch, and it will never fully engage . I've had this trouble in the past and turning down the washer to a smaller diameter solved the problem. Worth checing before you try something more complicated!
Cheers and Happy New Year.
Bob
RE: Ulster Rep Rebuild - Gearbox release bearing pressing on clutch arms - by Bob Kneale - 08-01-2025, 05:12 PM
