Ulster Rep Rebuild - Gearbox release bearing pressing on clutch arms
Hello everyone, my dad Erich and I are on the middle of an Ulster Rep rebuild, and we've run into an issue mounting the gearbox to the engine.
With the gearbox fully seated, the clutch bearing in the gearbox is pressing down on the clutch arms just enough to cause it to slip, without depressing the clutch pedal.
It seems like the release bearing we have won't fully seat onto the assembly, as there is a bit of a gap between the base of the assembly and the top of the bearing cage, even after hammering it on.
This setup looks to be a later type clutch release, with our setup using a leaf spring instead of the coil spring to pull the bearing back.
The clutch assembly is also a later type, with mousetrap springs and roller surfaces on the clutch arms, but no blind spline on the input shaft.
Since we are using a 3 speed crash box with the later type release, which was made to work with 4 speed gearboxes, we were wondering if the distance between the release bearing and the clutch arms could be widened in some way to avoid pressing into the clutch. Any help would be appreciated!
Ned Volkstorf
Ulster Rep Rebuild - Gearbox release bearing pressing on clutch arms - by Ned - 08-01-2025, 01:22 AM
