Block help needed.
If I was doing another block I would go for a set of Tony Betts slipper pistons.
The engine I'm using now has Honda pistons but I'm not altogether happy with it.
The original engine for the car is now back together with new rear main bearing and much better timing gears from Tony Leslie.
Probably the best solution. Should only take a day to do.
Block help needed. - by David Stepney - 06-01-2025, 11:20 AM
RE: Block help needed. - by daveg - 06-01-2025, 11:44 AM
RE: Block help needed. - by Charles P - 06-01-2025, 01:15 PM
RE: Block help needed. - by David Stepney - 06-01-2025, 01:35 PM
RE: Block help needed. - by AustinWood - 06-01-2025, 02:26 PM
RE: Block help needed. - by Howard Wright - 06-01-2025, 05:31 PM
RE: Block help needed. - by Greig Smith - 07-01-2025, 07:12 AM
