Put the rear axle back into the car - any advice
Hi
I use a furniture mover (a small board mounted on four castors). Put the banjo of the axle on this and you can manoeuvre the torque tube bracket over crossmember. I then jack up one side of the axle until it is level with the spring and manhandle the other side until I can get the spring pin in.
Remember to get the car as high as you can before you start and you may need to jack under the spring eye to get the pin in.
RE: Put the rear axle back into the car - any advice - by Howard Wright - 04-01-2025, 06:12 PM
