  • 1 Vote(s) - 4 Average
SU needles
Hi
The attached book has useful information including the needle profiles. As a starting point the needle must be chosen from a range designed for the size of jet used e.g. 0.090 inch.  Needle dimensions are critical to fractions of a thou especially around the idle end, so unless you are certain that the jet and needle have not worn against each other (they are not supposed to touch) I recommend you start with new ones.
For what it's worth, I run an SU H1 from a Morris 8 Series E, which is a 1 1/8 inch carb with a weighted piston. The chosen needle was GG, and road testing with a wideband oxygen sensor in the downpipe has shown that it is pretty well spot on for Air/Fuel ratio throughout the load and RPM range.  The sensor and display are not cheap, but I use them on other cars. A threaded boss has to be welded on to the downpipe and can be fitted with a blanking plug when the sensor is not required. Thoroughly recommended if you are serious about tuning, and much superior to any other method I have tried. The readout is pretty well instantaneous whilst driving.
.pdf   Tuning_SU_Carbs with charts Speedsport 1970.pdf (Size: 1.62 MB / Downloads: 30)
SU needles - by frequentflyer - 16-12-2024, 11:44 PM
RE: SU needles - by Hugh Barnes - 17-12-2024, 08:00 AM
RE: SU needles - by Belinni - 17-12-2024, 10:39 AM
RE: SU needles - by Ruairidh Dunford - 17-12-2024, 10:50 AM
RE: SU needles - by Chris KC - 17-12-2024, 10:59 AM
RE: SU needles - by `Gordonhbm - 17-12-2024, 11:58 AM
RE: SU needles - by GaryCullen - 17-12-2024, 11:36 PM
RE: SU needles - by Neil Morrison - 18-12-2024, 12:25 AM
RE: SU needles - by GaryCullen - 18-12-2024, 04:12 AM
RE: SU needles - by John Cornforth - 18-12-2024, 09:38 AM
RE: SU needles - by `Gordonhbm - 18-12-2024, 12:50 PM
RE: SU needles - by John Cornforth - 18-12-2024, 02:47 PM
RE: SU needles - by Alan - 18-12-2024, 03:00 PM
