  • 2 Vote(s) - 4.5 Average
Rear main bearing oil seal
I know this has been suggested but I believe some of the seal housings don't have the required groove to allow oil to drain back into the sump and the suppliers assume you will file this in yourself.
I bought mine from "Austin7Ulster" and it had the required groove already machined although only at one position which obviously needs to be at the bottom.
My engine had always leaked from the original scroll type seal and the modern lip seal together with a speedi sleeve on the flywheel boss virtually eliminated any leakage.
John.
Rear main bearing oil seal - by Dave Mann - 13-12-2024, 06:37 PM
RE: Rear main bearing oil seal - by Alan - 13-12-2024, 07:17 PM
RE: Rear main bearing oil seal - by Steve Jones - 13-12-2024, 07:57 PM
RE: Rear main bearing oil seal - by Dave Mann - 13-12-2024, 09:17 PM
RE: Rear main bearing oil seal - by Peter Naulls - 13-12-2024, 09:52 PM
RE: Rear main bearing oil seal - by Tony Press - 13-12-2024, 10:02 PM
RE: Rear main bearing oil seal - by dickie65 - 13-12-2024, 10:40 PM
RE: Rear main bearing oil seal - by Brice - 14-12-2024, 12:30 AM
RE: Rear main bearing oil seal - by Dave Mann - 14-12-2024, 11:30 AM
RE: Rear main bearing oil seal - by Steve Bryant - 14-12-2024, 03:16 PM
RE: Rear main bearing oil seal - by AustinWood - 14-12-2024, 04:46 PM
RE: Rear main bearing oil seal - by John P - 14-12-2024, 06:13 PM
RE: Rear main bearing oil seal - by Dave Mann - 15-12-2024, 10:31 AM
RE: Rear main bearing oil seal - by Dave Mann - 15-12-2024, 12:06 PM
RE: Rear main bearing oil seal - by Howard Wright - 15-12-2024, 12:39 PM
RE: Rear main bearing oil seal - by Alan - 15-12-2024, 12:42 PM
RE: Rear main bearing oil seal - by Terrytuned - 15-12-2024, 08:30 PM
RE: Rear main bearing oil seal - by AustinWood - 15-12-2024, 09:57 PM
RE: Rear main bearing oil seal - by Dave Mann - 16-12-2024, 03:16 PM
RE: Rear main bearing oil seal - by Reckless Rat - 16-12-2024, 06:36 PM
RE: Rear main bearing oil seal - by Parazine - 16-12-2024, 11:22 PM
RE: Rear main bearing oil seal - by Brice - 17-12-2024, 12:48 AM
RE: Rear main bearing oil seal - by Steve Jones - 17-12-2024, 12:13 PM
RE: Rear main bearing oil seal - by Brice - 17-12-2024, 12:46 PM
RE: Rear main bearing oil seal - by leaf200 - 17-12-2024, 01:07 PM
RE: Rear main bearing oil seal - by Dave Mann - 17-12-2024, 01:18 PM
RE: Rear main bearing oil seal - by Dave Mann - 18-12-2024, 09:00 PM
RE: Rear main bearing oil seal - by Dave Mann - 19-12-2024, 01:32 PM
RE: Rear main bearing oil seal - by Dave Mann - 20-12-2024, 10:12 PM
