  • 1 Vote(s) - 2 Average
New block
A 1929 block will fit a 1933 crankcase, but there are a few differences. Flanged valve guides are a smaller od than the straight type, so not interchangeable. The valve chest cover is not interchangeable as the fixings are in a different position. The core plugs are probably the earlier screw-in type, not knock-in as in 1933. None of these things are a problem, save for originality's sake.Looking at your photos, you might simply get away with tapping the water branch fixings to 3/8 bsf and using stepped studs (the usual suppliers will probably have these - stepped head studs would do). If the bores are really 2.235/7, you will probably need to re-bore and you should check if liners have been fitted previously - may not be advisable to bore these any larger.
New block - by Andy Bennett - 22-05-2018, 08:47 PM
RE: New block - by Nigel was in Brittany - 22-05-2018, 08:52 PM
RE: New block - by Andy Bennett - 22-05-2018, 09:03 PM
RE: New block - by bystander - 22-05-2018, 09:21 PM
RE: New block - by Hedd Jones - 22-05-2018, 09:28 PM
RE: New block - by Andy Bennett - 22-05-2018, 09:39 PM
RE: New block - by bystander - 22-05-2018, 09:50 PM
RE: New block - by Andy Bennett - 22-05-2018, 10:00 PM
RE: New block - by Chris KC - 22-05-2018, 10:42 PM
RE: New block - by Andy Bennett - 23-05-2018, 08:46 AM
RE: New block - by Chris KC - 23-05-2018, 08:58 AM
RE: New block - by Robert Leigh - 23-05-2018, 10:33 AM
RE: New block - by Terrytuned - 23-05-2018, 11:08 AM
RE: New block - by Andy Bennett - 23-05-2018, 07:18 PM
RE: New block - by Tony Press - 23-05-2018, 11:34 PM
RE: New block - by John Newell - 24-05-2018, 12:21 AM
RE: New block - by Bob Culver - 24-05-2018, 08:00 AM
RE: New block - by Andy Bennett - 25-05-2018, 09:49 AM
