24-11-2024, 07:15 PM
Okay, but my sump is fitted with 5/16" cap screws and spring washers. What I want to know is what was the length of the original bolts, because my thought is that 1/2" length isn't quite enough when the thickness of the flange and the washer is taken into consideration. Also, were spring washers fitted as well as the oval washers? Thanks.
Cheers, Geoffrey
