  • 1 Vote(s) - 3 Average
The right lathe
#24
I have an Emco Emcomat 7 with the longer bed. It's a nice, small machine. I did have to modify a set of Chinese mini-lathe gears to make a gear cutting set for it. I am set up to cut imperial threads. Setting up for cutting threads is always fiddly but it works fine. I have successfully made parts for my Riley on it. But it's really a modelling type lathe. It was my next small step up from a Chinese mini-lathe. The swing is only 3.5" from memory and it doesn't have a cut out in the bed. It's too small for me machine the big end of a Velocette LE con rod which isn't huge for example. Often consider getting a bigger, more useful machine then I remember what a pain it is to find and move and install them!
Simon
The right lathe - by Andy Bennett - 22-08-2024, 02:56 PM
RE: The right lathe - by Reckless Rat - 22-08-2024, 03:19 PM
RE: The right lathe - by Ivor Hawkins - 22-08-2024, 04:42 PM
RE: The right lathe - by Parazine - 22-08-2024, 06:56 PM
RE: The right lathe - by Charles P - 22-08-2024, 09:23 PM
RE: The right lathe - by Austin in the Shed - 22-08-2024, 11:00 PM
RE: The right lathe - by Charles P - 22-08-2024, 11:39 PM
RE: The right lathe - by Andy Bennett - 23-08-2024, 02:08 AM
RE: The right lathe - by Tony Griffiths - 23-08-2024, 11:34 AM
RE: The right lathe - by Andy Bennett - 23-08-2024, 02:50 PM
RE: The right lathe - by bob46320 - 23-08-2024, 04:30 PM
RE: The right lathe - by Reckless Rat - 23-08-2024, 05:33 PM
RE: The right lathe - by Andy Bennett - 23-08-2024, 06:48 PM
RE: The right lathe - by Stumpi - 23-08-2024, 09:17 PM
RE: The right lathe - by Charles P - 23-08-2024, 10:34 PM
RE: The right lathe - by Tony Griffiths - 24-08-2024, 12:12 AM
RE: The right lathe - by Andy Bennett - 25-10-2024, 07:31 PM
RE: The right lathe - by Charles P - 25-10-2024, 10:39 PM
RE: The right lathe - by Andy Bennett - 26-10-2024, 07:29 AM
RE: The right lathe - by Dave Mann - 26-10-2024, 10:10 AM
RE: The right lathe - by dickie65 - 26-10-2024, 11:48 AM
RE: The right lathe - by Robert Foreman - 26-10-2024, 12:46 PM
RE: The right lathe - by Tony Griffiths - 28-10-2024, 08:19 PM
RE: The right lathe - by jansens - 07-11-2024, 09:11 PM
RE: The right lathe - by Ian Williams - 07-11-2024, 11:03 PM
RE: The right lathe - by Tony Griffiths - 08-11-2024, 10:49 AM
