  • 1 Vote(s) - 1 Average
Chassis repair steel
Hi All
Grovelling under the Green Van last week I noticed a strange vertical line on the near side chassis leg just behind the brake cross shaft.  Further examination revealed some serious corrosion skilfully hidden under globs of underseal and a crack.
.jpeg   IMG_4632.jpeg (Size: 104.17 KB / Downloads: 501)
.jpeg   IMG_4633.jpeg (Size: 114.13 KB / Downloads: 501)
I did wonder if I could repair in situ but I’ve taken the plunge and am removing the body.
The corrosion is visible from just aft of the front cross shaft to just before the spring housing although I’m sure more will be revealed when the body is off.  Strangely the offside of the chassis looks to be in reasonable condition.
So how would forum members go about repairing this?  I’m assuming that new steel will have to replace old but what steel would be best to use (ordinary mild steel or something higher yield).  I’m tempted to weld a 38mm square box section into the U shape chassis profile.
But if someone has a good condition near side short wheelbase chassis leg in their shed?
Chassis repair steel - by Howard Wright - 06-11-2024, 06:37 PM
RE: Chassis repair steel - by Colin Bromley - 06-11-2024, 07:52 PM
RE: Chassis repair steel - by Ivor Hawkins - 06-11-2024, 08:50 PM
RE: Chassis repair steel - by Howard Wright - 06-11-2024, 08:53 PM
RE: Chassis repair steel - by Ian Williams - 06-11-2024, 10:45 PM
RE: Chassis repair steel - by Chris KC - 06-11-2024, 11:42 PM
RE: Chassis repair steel - by Hugh Barnes - 07-11-2024, 07:56 AM
RE: Chassis repair steel - by Ivor Hawkins - 07-11-2024, 12:08 PM
RE: Chassis repair steel - by Howard Wright - 07-11-2024, 12:11 PM
RE: Chassis repair steel - by Reckless Rat - 07-11-2024, 01:39 PM
RE: Chassis repair steel - by Howard Wright - 07-11-2024, 06:44 PM
RE: Chassis repair steel - by Ivor Hawkins - 07-11-2024, 06:57 PM
RE: Chassis repair steel - by Howard Wright - 07-11-2024, 07:09 PM
RE: Chassis repair steel - by Howard Wright - 22-12-2024, 04:28 PM
