Brake light switch operation
It should always have a spring in the connection. This ensures that when braking in extremity the brake pedal application is not limited by the switch travel and/or the switch is not destroyed by massive force. The internal spring in the switch is weaker as it only needs to overcome the weight of the pedal after the size 12 boot has been removed.
Brake light switch operation - by wild_willy - 16-07-2023, 09:12 AM
RE: Brake light switch operation - by wild_willy - 16-07-2023, 09:49 PM
RE: Brake light switch operation - by falcott - 29-10-2024, 03:39 AM
RE: Brake light switch operation - by Pearls not a Singer - 29-10-2024, 06:44 PM
RE: Brake light switch operation - by falcott - 31-10-2024, 03:15 AM
