austin ulster replica
(21-05-2018, 08:28 AM)Colin Wilks Wrote:
(21-05-2018, 07:57 AM)lolforre43 Wrote: I've just acquired a 1936 Ulster having no experience of pre-war cars and I have number of queries for which any advice would be welcome.
1. the car jumps out of first gear, which I was told is normal. Is this actually the case and if not does it indicate significant wear in the gearbox ?        2. the car judders violently in reverse; clutch problems or engine mountings ?        3. what are the correct tyre pressures ?        4. does anyone produce copies of the original owners manual or something similar ?
I think that's enough for now, though I'm sure there'll be more. All help gratefully received.
Lawrence Forrester
Hi Lawrence,
1. Seems an unlikely design feature.
2. Use the clutch as an on/off device. Don't try to slip it as you do in a modern car.
3. Original recommendation is 22 psi. I've just replaced my tyres (3.50-19) at Longstone, who recommend 30 psi and this seems OK to me.
4. See http://archive.a7ca.org/collections/hand...rts-lists/
5. Join the Pre War A7 Club! I'm new to Sevens and have had loads of help and advice from other owners. https://www.pwa7c.co.uk/join.php
Good luck,
Colin
austin ulster replica - by lolforre43 - 21-05-2018, 07:57 AM
RE: austin ulster replica - by Colin Wilks - 21-05-2018, 08:28 AM
RE: austin ulster replica - by lolforre43 - 21-05-2018, 10:47 AM
RE: austin ulster replica - by lolforre43 - 21-05-2018, 11:06 AM
RE: austin ulster replica - by Chris KC - 21-05-2018, 08:39 AM
RE: austin ulster replica - by JonE - 21-05-2018, 08:43 AM
RE: austin ulster replica - by bob46320 - 21-05-2018, 09:39 AM
RE: austin ulster replica - by Robert Leigh - 21-05-2018, 11:00 AM
RE: austin ulster replica - by JonE - 21-05-2018, 12:28 PM
