Brake Pedal ratio.
I'm fitting Morris Minor 7" brakes to my Austin Seven Special. As I understand it, the Morris has a 13/16" diameter master cylinder.
Can anyone with a similar set-up please let me know what the correct pedal ratio is?
Also, are there any modern type track rod ends available that will fit the Austin drag link in place of the original type? i.e. with the same taper.
Thank you.
Brake Pedal ratio. - by Mike Morley - Yesterday, 05:05 PM
