Sump Studs v Bolts
None of my engines have anything other than the standard size/shape sump. However, all but one are cast aluminium versions rather than the original pressed steel. With the standard size/shape sump, there's no need to remove it to take the engine out be it pressed steel or cast aluminium and whether it's secured with bolts or studs/nuts is irrelevant. If the sump is larger than standard then, of course, it may need removal depending on its size, shape and fitment.
Sump Studs v Bolts - by Rick F - 21-10-2024, 11:24 AM
RE: Sump Studs v Bolts - by Alan - 21-10-2024, 11:40 AM
RE: Sump Studs v Bolts - by Steve Jones - 21-10-2024, 11:45 AM
RE: Sump Studs v Bolts - by Alan - 21-10-2024, 01:03 PM
RE: Sump Studs v Bolts - by AustinWood - 21-10-2024, 04:00 PM
RE: Sump Studs v Bolts - by Chris KC - 21-10-2024, 04:20 PM
RE: Sump Studs v Bolts - by falcott - 21-10-2024, 07:31 PM
RE: Sump Studs v Bolts - by Nick Salmon - 21-10-2024, 07:36 PM
RE: Sump Studs v Bolts - by Charles P - 21-10-2024, 09:56 PM
RE: Sump Studs v Bolts - by Rick F - 21-10-2024, 11:58 PM
RE: Sump Studs v Bolts - by Hugh Barnes - 22-10-2024, 08:54 AM
RE: Sump Studs v Bolts - by Steve Jones - 22-10-2024, 11:07 AM
RE: Sump Studs v Bolts - by Rick F - 22-10-2024, 11:51 AM
RE: Sump Studs v Bolts - by Charles P - 22-10-2024, 12:41 PM
RE: Sump Studs v Bolts - by Alan - 22-10-2024, 01:10 PM
RE: Sump Studs v Bolts - by Charles P - 22-10-2024, 01:40 PM
RE: Sump Studs v Bolts - by Steve Jones - 22-10-2024, 02:21 PM
RE: Sump Studs v Bolts - by stuartu - 22-10-2024, 03:06 PM
RE: Sump Studs v Bolts - by Rick F - 23-10-2024, 12:06 AM
RE: Sump Studs v Bolts - by Steve Jones - 23-10-2024, 06:12 PM
RE: Sump Studs v Bolts - by Rick F - 23-10-2024, 11:56 PM
RE: Sump Studs v Bolts - by Ruairidh Dunford - 24-10-2024, 08:54 AM
RE: Sump Studs v Bolts - by Cliff Ringrose - 24-10-2024, 12:06 PM
RE: Sump Studs v Bolts - by Rick F - 24-10-2024, 01:18 PM
RE: Sump Studs v Bolts - by dickie65 - 25-10-2024, 08:13 PM
