21-05-2018, 09:39 AM
"clutch judder" Are the prop shaft anchor points too sloppy ? If you can rattle the joint (between the axle casing and centre of the prop shaft) then it needs adjusting. You can remove slack by both adjusting the ball joint from the prop shaft case to the chassis also the large screwed collar around the prop shaft casing. If you have rubber mounts on your engine, they are probably perished and need replacing / tightening - early engines were bolted directly to the chassis, where the rear bolts are tight, and the front bolts are tight minus about 1/2 to 1 thread.
