Front Hub Removal
Perhaps Loctite has been used to hold the bearing in place.
In which case heat may help, if a severe grade has been used, quite a lot of heat will be required.
Usually, fronts come off with not a lot of effort., hammer not needed.
Make sure the extractor is well on the threads, they are easily damaged.
Front Hub Removal - by themaces - 15-10-2024, 07:32 PM
RE: Front Hub Removal - by "Slack Alice" Simon - 16-10-2024, 12:21 PM
RE: Front Hub Removal - by stuartu - 16-10-2024, 12:29 PM
RE: Front Hub Removal - by themaces - 17-11-2024, 12:25 PM
RE: Front Hub Removal - by Ruairidh Dunford - 17-11-2024, 10:50 PM
