  • 1 Vote(s) - 1 Average
Uncoupled brakes conversion?
#25
I once saw a Chummy where the flexi-brackets had been replaced by a pair of plumber blocks, like these with self-aligning bearings to accommodate chassis flex. Another trick is to brace the flexi brackets with a strut to the cross-shaft. In 1965, seeing that the offside bracket was starting to tear away from the chassis, I made up a two-part, screw-together tube with a slot at one end to locate against the bracket and turned the two parts to push the bracket back into place. It stayed there for the next 120,000 + miles.
.jpg   Plumber blocks.jpg (Size: 44.94 KB / Downloads: 289)
Uncoupled brakes conversion? - by Hurvinek - 29-09-2024, 09:02 AM
RE: Uncoupled brakes conversion? - by Hurvinek - 29-09-2024, 09:43 AM
RE: Uncoupled brakes conversion? - by Hurvinek - 29-09-2024, 06:40 PM
RE: Uncoupled brakes conversion? - by Hurvinek - 03-10-2024, 07:23 AM
RE: Uncoupled brakes conversion? - by Lowespeed - 04-10-2024, 12:13 PM
RE: Uncoupled brakes conversion? - by Steve kay - 04-10-2024, 02:02 PM
RE: Uncoupled brakes conversion? - by Tony Press - 05-10-2024, 10:00 PM
RE: Uncoupled brakes conversion? - by `Gordonhbm - 07-10-2024, 04:09 PM
RE: Uncoupled brakes conversion? - by Tony Press - 07-10-2024, 09:49 PM
RE: Uncoupled brakes conversion? - by `Gordonhbm - 08-10-2024, 10:28 AM
RE: Uncoupled brakes conversion? - by Lowespeed - 08-10-2024, 10:33 AM
RE: Uncoupled brakes conversion? - by Tony Griffiths - 09-10-2024, 10:40 AM
RE: Uncoupled brakes conversion? - by Hurvinek - 09-10-2024, 08:02 PM
RE: Uncoupled brakes conversion? - by Ray White - 09-10-2024, 09:46 PM
RE: Uncoupled brakes conversion? - by Hurvinek - 10-10-2024, 09:42 PM
RE: Uncoupled brakes conversion? - by Ray White - 13-10-2024, 10:21 AM
