Block question?
It looks like the block has liners fitted, so the cracks should not cause a problem into the bores.
Use a good quality ceramic block sealer once everything is back together and it will likely be fine until you have another engine ready for it.
You should be able to helicoil the centre stud hole to take a 3/8 bsf stepped stud. Use Loctite to secure both.
Block question? - by Howard Wright - 26-09-2024, 03:41 PM
RE: Block question? - by Ruairidh Dunford - 26-09-2024, 04:32 PM
RE: Block question? - by Howard Wright - 26-09-2024, 04:56 PM
RE: Block question? - by Ian Williams - 26-09-2024, 09:14 PM
RE: Block question? - by Howard Wright - 27-09-2024, 07:31 AM
RE: Block question? - by Austin in the Shed - 27-09-2024, 09:30 AM
RE: Block question? - by Ian Williams - 27-09-2024, 10:16 PM
RE: Block question? - by Howard Wright - 28-09-2024, 07:50 AM
