Battery overcharging.
#25
Hi Ian
The 100 Watt rating for this type of metalclad resistor applies when it's bolted to a heatsink. If you choose to leave it sitting in free air the rating is more like 20 Watts. That should still be fine though, the reduced field current through it when it's in use will be roughly 1 amp and the dissipation will only be about 2 watts. This means the surface temperature won't be too high and you can mount it wherever it's convenient.
Battery overcharging. - by Ian Wegg - 20-09-2024, 07:46 AM
RE: Battery overcharging. - by Howard Wright - 20-09-2024, 07:58 AM
RE: Battery overcharging. - by Andy Bennett - 20-09-2024, 09:24 AM
RE: Battery overcharging. - by Dave Mann - 20-09-2024, 10:37 AM
RE: Battery overcharging. - by AustinWood - 20-09-2024, 11:38 AM
RE: Battery overcharging. - by Ian Wegg - 20-09-2024, 03:13 PM
RE: Battery overcharging. - by Reckless Rat - 20-09-2024, 03:40 PM
RE: Battery overcharging. - by Ian Wegg - 20-09-2024, 04:52 PM
RE: Battery overcharging. - by Dave Mann - 20-09-2024, 08:35 PM
RE: Battery overcharging. - by Tony Press - 21-09-2024, 01:28 AM
RE: Battery overcharging. - by Robert Leigh - 21-09-2024, 10:51 AM
RE: Battery overcharging. - by Reckless Rat - 21-09-2024, 10:54 AM
RE: Battery overcharging. - by Dave Mann - 21-09-2024, 11:14 AM
RE: Battery overcharging. - by David Stepney - 21-09-2024, 05:24 PM
RE: Battery overcharging. - by Tony Press - 21-09-2024, 11:24 PM
RE: Battery overcharging. - by Tony Griffiths - 21-09-2024, 11:30 PM
RE: Battery overcharging. - by Ian Wegg - 22-09-2024, 10:32 AM
RE: Battery overcharging. - by Dave Mann - 22-09-2024, 11:51 AM
RE: Battery overcharging. - by David Stepney - 22-09-2024, 12:11 PM
RE: Battery overcharging. - by Ian Wegg - 22-09-2024, 01:05 PM
RE: Battery overcharging. - by Dave Mann - 22-09-2024, 02:41 PM
RE: Battery overcharging. - by Tony Griffiths - 24-09-2024, 04:33 PM
RE: Battery overcharging. - by Ian Wegg - 25-09-2024, 08:58 AM
RE: Battery overcharging. - by John Cornforth - 25-09-2024, 11:38 AM
RE: Battery overcharging. - by gezparton - 25-09-2024, 12:36 PM
RE: Battery overcharging. - by Robert Leigh - 25-09-2024, 02:27 PM
RE: Battery overcharging. - by Ian Wegg - 25-09-2024, 04:32 PM
RE: Battery overcharging. - by John Cornforth - 25-09-2024, 06:42 PM
RE: Battery overcharging. - by AustinWood - 25-09-2024, 07:04 PM
Users browsing this thread: 17 Guest(s)
