21-09-2024, 10:34 PM
Hi folks!
I am unsure...
Can I just change the cylinder head without any problems, or are there other things that need to be done?
Do I maybe need to change the ignition timing, adjust the valves, or something else? Or just screw the other head on... bam, done? Using the correct head gasket is obvious.
If someone could explain this to me, I would be happy.
Thank you very much!
Oliver
I am unsure...
Oliver
