Battery overcharging.
That is a lot on half charge.
I suggest the resistor in the system has been shorted out.
The original resistor looks like a spring, and may be located in the base of the control box, or in a mounting on the dynamo.
On half charge, it is in series with the dynamo field coil, and so reduces the output.
The main control of the output is by moving the third brush on the dynamo, as I guess those articles will explain.
My point is, if you are getting 12 amps on half charge, the circuit needs to be investigated
Assuming you have a standard dynamo.
Battery overcharging. - by Ian Wegg - 20-09-2024, 07:46 AM
RE: Battery overcharging. - by Howard Wright - 20-09-2024, 07:58 AM
RE: Battery overcharging. - by "Slack Alice" Simon - 20-09-2024, 08:49 AM
RE: Battery overcharging. - by Andy Bennett - 20-09-2024, 09:24 AM
RE: Battery overcharging. - by Dave Mann - 20-09-2024, 10:37 AM
RE: Battery overcharging. - by AustinWood - 20-09-2024, 11:38 AM
RE: Battery overcharging. - by Ian Wegg - 20-09-2024, 03:13 PM
RE: Battery overcharging. - by Reckless Rat - 20-09-2024, 03:40 PM
RE: Battery overcharging. - by Ian Wegg - 20-09-2024, 04:52 PM
RE: Battery overcharging. - by Dave Mann - 20-09-2024, 08:35 PM
RE: Battery overcharging. - by Tony Press - 21-09-2024, 01:28 AM
RE: Battery overcharging. - by Robert Leigh - 21-09-2024, 10:51 AM
RE: Battery overcharging. - by Reckless Rat - 21-09-2024, 10:54 AM
RE: Battery overcharging. - by Dave Mann - 21-09-2024, 11:14 AM
RE: Battery overcharging. - by David Stepney - 21-09-2024, 05:24 PM
RE: Battery overcharging. - by Tony Press - 21-09-2024, 11:24 PM
RE: Battery overcharging. - by Tony Griffiths - 21-09-2024, 11:30 PM
RE: Battery overcharging. - by Ian Wegg - 22-09-2024, 10:32 AM
RE: Battery overcharging. - by Dave Mann - 22-09-2024, 11:51 AM
RE: Battery overcharging. - by David Stepney - 22-09-2024, 12:11 PM
RE: Battery overcharging. - by Ian Wegg - 22-09-2024, 01:05 PM
RE: Battery overcharging. - by Dave Mann - 22-09-2024, 02:41 PM
RE: Battery overcharging. - by Tony Griffiths - 24-09-2024, 04:33 PM
RE: Battery overcharging. - by Ian Wegg - 25-09-2024, 08:58 AM
RE: Battery overcharging. - by John Cornforth - 25-09-2024, 11:38 AM
RE: Battery overcharging. - by gezparton - 25-09-2024, 12:36 PM
RE: Battery overcharging. - by Robert Leigh - 25-09-2024, 02:27 PM
RE: Battery overcharging. - by Ian Wegg - 25-09-2024, 04:32 PM
RE: Battery overcharging. - by John Cornforth - 25-09-2024, 06:42 PM
RE: Battery overcharging. - by AustinWood - 25-09-2024, 07:04 PM
