A New Austin Seven Owner
#28
Opinions vary of the efficacy of the Bowdenex conversion, but rubbing on the tyre isn't recommended. I would guess it might be best to re-route it, but the system is outwith my experience. To be fair Austin Seven brakes are nothing like as efficient as on a modern. The original cable set-up is adequate though, if properly set up.
If your semaphore indicators are working, you can get flashing LED bulbs to replace the originals. They might make them easier to spot. Too many drivers about these days that haven't got a clue what they are.
You can get them here (I have no connection with the seller by the way) https://www.dynamoregulatorconversions.c...c/28044330, although you might have indicators incorporated in the sidelights?
Your car is also running on 17" wheels with Avon 4.50 -17 tyres, which is non-standard for an RP saloon. They should be 19" rims with 3.50-19 tyres. Not really "wrong" as such, probably a period modification. The Ruby series cars ran on 17"
A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 05:28 PM
RE: A New Austin Seven Owner - by Reckless Rat - 04-09-2024, 05:47 PM
RE: A New Austin Seven Owner - by Chris KC - 04-09-2024, 06:09 PM
RE: A New Austin Seven Owner - by Mike Costigan - 04-09-2024, 07:00 PM
RE: A New Austin Seven Owner - by Howard Wright - 04-09-2024, 07:06 PM
RE: A New Austin Seven Owner - by Andy Bennett - 04-09-2024, 07:13 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 07:19 PM
RE: A New Austin Seven Owner - by John Cornforth - 04-09-2024, 07:26 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 07:46 PM
RE: A New Austin Seven Owner - by David Stepney - 04-09-2024, 07:49 PM
RE: A New Austin Seven Owner - by andrew34ruby - 04-09-2024, 07:50 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 08:20 PM
RE: A New Austin Seven Owner - by Steve kay - 04-09-2024, 08:21 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 08:22 PM
RE: A New Austin Seven Owner - by David Stepney - 04-09-2024, 08:45 PM
RE: A New Austin Seven Owner - by Howard Wright - 04-09-2024, 09:17 PM
RE: A New Austin Seven Owner - by Tony Griffiths - 05-09-2024, 10:01 AM
RE: A New Austin Seven Owner - by JohnD - 05-09-2024, 11:12 AM
RE: A New Austin Seven Owner - by Nick Salmon - 05-09-2024, 11:21 AM
RE: A New Austin Seven Owner - by Reckless Rat - 05-09-2024, 01:03 PM
RE: A New Austin Seven Owner - by Turboseven412 - 05-09-2024, 03:53 PM
RE: A New Austin Seven Owner - by David Stepney - 05-09-2024, 06:27 PM
RE: A New Austin Seven Owner - by Turboseven412 - 05-09-2024, 07:07 PM
RE: A New Austin Seven Owner - by Turboseven412 - 06-09-2024, 04:36 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 05:20 PM
RE: A New Austin Seven Owner - by Turboseven412 - 06-09-2024, 07:03 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 07:27 PM
RE: A New Austin Seven Owner - by Howard Wright - 06-09-2024, 07:42 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 07:59 PM
RE: A New Austin Seven Owner - by John Cornforth - 06-09-2024, 08:28 PM
RE: A New Austin Seven Owner - by Turboseven412 - 07-09-2024, 10:13 AM
RE: A New Austin Seven Owner - by Chris Garner - 07-09-2024, 10:38 AM
RE: A New Austin Seven Owner - by Robert Leigh - 07-09-2024, 01:29 PM
RE: A New Austin Seven Owner - by Hugh Barnes - 07-09-2024, 01:45 PM
RE: A New Austin Seven Owner - by Ivor Hawkins - 07-09-2024, 07:24 PM
RE: A New Austin Seven Owner - by andrew34ruby - 07-09-2024, 07:29 PM
RE: A New Austin Seven Owner - by Nick Salmon - 07-09-2024, 08:06 PM
RE: A New Austin Seven Owner - by Reckless Rat - 07-09-2024, 08:55 PM
RE: A New Austin Seven Owner - by Turboseven412 - 07-09-2024, 09:59 PM
RE: A New Austin Seven Owner - by David Stepney - 07-09-2024, 10:37 PM
RE: A New Austin Seven Owner - by Tony Press - 07-09-2024, 11:32 PM
RE: A New Austin Seven Owner - by Chris Garner - 09-09-2024, 08:49 AM
RE: A New Austin Seven Owner - by Howard Wright - 09-09-2024, 09:27 AM
RE: A New Austin Seven Owner - by David Stepney - 09-09-2024, 10:00 AM
RE: A New Austin Seven Owner - by Reckless Rat - 09-09-2024, 10:22 AM
