A New Austin Seven Owner
#21
The knocking sound is probably not due to the king pin, it'll be something inside the front brake. I would leave the king pins alone unless you're absolutely sure they're knackered. The noise might be due to a brake lining coming adrift or a loose pivot. Do the little and easy things first.
A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 05:28 PM
RE: A New Austin Seven Owner - by Reckless Rat - 04-09-2024, 05:47 PM
RE: A New Austin Seven Owner - by Chris KC - 04-09-2024, 06:09 PM
RE: A New Austin Seven Owner - by Mike Costigan - 04-09-2024, 07:00 PM
RE: A New Austin Seven Owner - by Howard Wright - 04-09-2024, 07:06 PM
RE: A New Austin Seven Owner - by Andy Bennett - 04-09-2024, 07:13 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 07:19 PM
RE: A New Austin Seven Owner - by John Cornforth - 04-09-2024, 07:26 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 07:46 PM
RE: A New Austin Seven Owner - by David Stepney - 04-09-2024, 07:49 PM
RE: A New Austin Seven Owner - by andrew34ruby - 04-09-2024, 07:50 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 08:20 PM
RE: A New Austin Seven Owner - by Steve kay - 04-09-2024, 08:21 PM
RE: A New Austin Seven Owner - by Turboseven412 - 04-09-2024, 08:22 PM
RE: A New Austin Seven Owner - by David Stepney - 04-09-2024, 08:45 PM
RE: A New Austin Seven Owner - by Howard Wright - 04-09-2024, 09:17 PM
RE: A New Austin Seven Owner - by Tony Griffiths - 05-09-2024, 10:01 AM
RE: A New Austin Seven Owner - by JohnD - 05-09-2024, 11:12 AM
RE: A New Austin Seven Owner - by Nick Salmon - 05-09-2024, 11:21 AM
RE: A New Austin Seven Owner - by Reckless Rat - 05-09-2024, 01:03 PM
RE: A New Austin Seven Owner - by Turboseven412 - 05-09-2024, 03:53 PM
RE: A New Austin Seven Owner - by David Stepney - 05-09-2024, 06:27 PM
RE: A New Austin Seven Owner - by Turboseven412 - 05-09-2024, 07:07 PM
RE: A New Austin Seven Owner - by Turboseven412 - 06-09-2024, 04:36 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 05:20 PM
RE: A New Austin Seven Owner - by Turboseven412 - 06-09-2024, 07:03 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 07:27 PM
RE: A New Austin Seven Owner - by Howard Wright - 06-09-2024, 07:42 PM
RE: A New Austin Seven Owner - by Reckless Rat - 06-09-2024, 07:59 PM
RE: A New Austin Seven Owner - by John Cornforth - 06-09-2024, 08:28 PM
RE: A New Austin Seven Owner - by Turboseven412 - 07-09-2024, 10:13 AM
RE: A New Austin Seven Owner - by Chris Garner - 07-09-2024, 10:38 AM
RE: A New Austin Seven Owner - by Robert Leigh - 07-09-2024, 01:29 PM
RE: A New Austin Seven Owner - by Hugh Barnes - 07-09-2024, 01:45 PM
RE: A New Austin Seven Owner - by Ivor Hawkins - 07-09-2024, 07:24 PM
RE: A New Austin Seven Owner - by andrew34ruby - 07-09-2024, 07:29 PM
RE: A New Austin Seven Owner - by Nick Salmon - 07-09-2024, 08:06 PM
RE: A New Austin Seven Owner - by Reckless Rat - 07-09-2024, 08:55 PM
RE: A New Austin Seven Owner - by Turboseven412 - 07-09-2024, 09:59 PM
RE: A New Austin Seven Owner - by David Stepney - 07-09-2024, 10:37 PM
RE: A New Austin Seven Owner - by Tony Press - 07-09-2024, 11:32 PM
RE: A New Austin Seven Owner - by Chris Garner - 09-09-2024, 08:49 AM
RE: A New Austin Seven Owner - by Howard Wright - 09-09-2024, 09:27 AM
RE: A New Austin Seven Owner - by David Stepney - 09-09-2024, 10:00 AM
RE: A New Austin Seven Owner - by Reckless Rat - 09-09-2024, 10:22 AM
