Steering problem
Good evening
I have been reading the mail from Malcolm Parker (2017) about his problem with the steering wheel nut when tightened up jamming the steering box. I have read the various solutions and can see that a circlip could solve the problem. Only problem is that the indent to which I would fit the circlip is up against the end of the outer tube so would not solve the problem. I cannot move the outer shaft even having released the clamping bolt. I am guessing the only solution is to reduce the length of the outer tube or to engineer a tab washer arrangement to prevent the nut undoing. Wondering if any one has any other ideas.
Martin Nash
Steering problem - by Malcolm Parker - 15-11-2021, 12:14 PM
RE: Steering problem - by Austin in the Shed - 15-11-2021, 12:50 PM
RE: Steering problem - by Dennis Nicholas - 15-11-2021, 05:26 PM
RE: Steering problem - by Steve Jones - 15-11-2021, 05:55 PM
RE: Steering problem - by Dennis Nicholas - 15-11-2021, 06:25 PM
RE: Steering problem - by Ruairidh Dunford - 15-11-2021, 09:48 PM
RE: Steering problem - by Malcolm Parker - 15-11-2021, 10:12 PM
RE: Steering problem - by Steve Jones - 16-11-2021, 01:20 PM
RE: Steering problem - by Malcolm Parker - 16-11-2021, 01:51 PM
RE: Steering problem - by Steve Jones - 16-11-2021, 03:30 PM
RE: Steering problem - by Malcolm Parker - 16-11-2021, 04:05 PM
RE: Steering problem - by Martin Nash - 01-09-2024, 06:13 PM
RE: Steering problem - by Malcolm Parker - 01-09-2024, 07:14 PM
RE: Steering problem - by Martin Nash - 02-09-2024, 12:37 PM
