31-08-2017, 08:09 PM
A fitted bearing may have almost no clearance so is not well suited to Flexiiguage type product. Care also necessary with old stock whcih becomes too hard.
Effective economica and completely reliable solutions are regularly dismissed as bodges on this forum. A neatly fitted shim to correct poorly fitted halves or to simplify the refitting to a larger shaft is not a bodge.
Shims can be shaped so that when flush with the exterior surface, not rubbing on the shaft.
