  • 1 Vote(s) - 3 Average
The right lathe
Don't write off second hand lathes, there are some real bargains to be had in ex-industrial quality machines at the same money as you will pay for poor quality Chinese stuff!
I have a Colchester Bantam, a minature heavy duty lathe. I don't have room for a Student, which is quite a lot larger and heavier The Bantam is superbly built, mine is ex-school, so not really much used. I converted it to single phase but could haveĀ used it with an inverter.
Much better than a cheap far-eastern lathe. which you should avoid at any price and more versatile than a Myford which, although a quality job, is really a modelmakers machine at 3 1/2" centre height (7" swing). Several local Austin 7 friends have Bantams as well.
Another alternative is a Boxford, which is not quite as robust as a Bantam but well made. Raglan Little John lathes have a keen following.
The right lathe - by Andy Bennett - 22-08-2024, 02:56 PM
RE: The right lathe - by Reckless Rat - 22-08-2024, 03:19 PM
RE: The right lathe - by Ivor Hawkins - 22-08-2024, 04:42 PM
RE: The right lathe - by Parazine - 22-08-2024, 06:56 PM
RE: The right lathe - by Charles P - 22-08-2024, 09:23 PM
RE: The right lathe - by Austin in the Shed - 22-08-2024, 11:00 PM
RE: The right lathe - by Charles P - 22-08-2024, 11:39 PM
RE: The right lathe - by Andy Bennett - 23-08-2024, 02:08 AM
RE: The right lathe - by Tony Griffiths - 23-08-2024, 11:34 AM
RE: The right lathe - by Andy Bennett - 23-08-2024, 02:50 PM
RE: The right lathe - by bob46320 - 23-08-2024, 04:30 PM
RE: The right lathe - by Reckless Rat - 23-08-2024, 05:33 PM
RE: The right lathe - by Andy Bennett - 23-08-2024, 06:48 PM
RE: The right lathe - by Stumpi - 23-08-2024, 09:17 PM
RE: The right lathe - by Charles P - 23-08-2024, 10:34 PM
RE: The right lathe - by Tony Griffiths - 24-08-2024, 12:12 AM
RE: The right lathe - by Andy Bennett - 25-10-2024, 07:31 PM
RE: The right lathe - by Charles P - 25-10-2024, 10:39 PM
RE: The right lathe - by Andy Bennett - 26-10-2024, 07:29 AM
RE: The right lathe - by Dave Mann - 26-10-2024, 10:10 AM
RE: The right lathe - by dickie65 - 26-10-2024, 11:48 AM
RE: The right lathe - by Robert Foreman - 26-10-2024, 12:46 PM
RE: The right lathe - by Tony Griffiths - 28-10-2024, 08:19 PM
RE: The right lathe - by jansens - 07-11-2024, 09:11 PM
RE: The right lathe - by Ian Williams - 07-11-2024, 11:03 PM
RE: The right lathe - by Tony Griffiths - 08-11-2024, 10:49 AM
