3 bearing case with a Phoenix crank modification
I have removed the centre main bearing from the 3 bearing crankcase  to fit a Phoenix pressure fed 2 bearing crank. I now have no idea how to provide a block stud for the centre of the right hand side of the block where the centre main bolt used to be.
What have other people done to sort the missing stud which is part of the centre main hold down stud/bolt?
Also what do people do about providing additional lubrication to the plain cam centre bearing? Maybe a track cut into the bearing surface may help?
Thanks for any suggestions for the above.
Bruce
3 bearing case with a Phoenix crank modification - by wild_willy - 22-08-2024, 08:52 AM
