Constant misfire ??????
#38
(16-08-2024, 12:49 PM)`Gordonhbm Wrote: It is worth checking  that the piston travels freely in the dashpot.  I would talk to Burlen on how to carry out a piston drop test for your specific model and what the drop time should be.   Also make sure that the holding down lugs on the dashpot are not damaged in any way as this can resulting the dashpot not sitting down correctly and interfering with correct piston movement.
Not sure SU were ever fitted as standard to Austin 7's, so it's unlikely Burlen could answer the question, but as so many SU's have been retrofitted, what's the best needle for my 1.1/8th dia model possibly ex 803cc Morris ????
Constant misfire ?????? - by Bluebird7 - 13-07-2024, 07:45 PM
RE: Constant misfire ?????? - by Nick Salmon - 13-07-2024, 07:56 PM
RE: Constant misfire ?????? - by Bluebird7 - 13-07-2024, 08:30 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 13-07-2024, 08:33 PM
RE: Constant misfire ?????? - by Ivor Hawkins - 13-07-2024, 08:37 PM
RE: Constant misfire ?????? - by Bluebird7 - 13-07-2024, 09:04 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 13-07-2024, 09:08 PM
RE: Constant misfire ?????? - by Bluebird7 - 13-07-2024, 09:26 PM
RE: Constant misfire ?????? - by Robert Leigh - 13-07-2024, 09:39 PM
RE: Constant misfire ?????? - by Bluebird7 - 13-07-2024, 09:49 PM
RE: Constant misfire ?????? - by John Mason - 17-07-2024, 09:55 AM
RE: Constant misfire ?????? - by JohnD - 17-07-2024, 10:31 AM
RE: Constant misfire ?????? - by Colin Morgan - 17-07-2024, 10:53 AM
RE: Constant misfire ?????? - by AustinWood - 17-07-2024, 11:09 AM
RE: Constant misfire ?????? - by John Mason - 17-07-2024, 11:47 AM
RE: Constant misfire ?????? - by bob46320 - 17-07-2024, 08:59 PM
RE: Constant misfire ?????? - by Charles Levien - 20-07-2024, 09:18 AM
RE: Constant misfire ?????? - by AustinWood - 20-07-2024, 10:52 AM
RE: Constant misfire ?????? - by Howard Wright - 20-07-2024, 11:13 AM
RE: Constant misfire ?????? - by Bluebird7 - 21-07-2024, 09:25 PM
RE: Constant misfire ?????? - by Charles Levien - 23-07-2024, 05:46 PM
RE: Constant misfire ?????? - by Tony Griffiths - 23-07-2024, 07:39 PM
RE: Constant misfire ?????? - by Bluebird7 - 23-07-2024, 09:31 PM
RE: Constant misfire ?????? - by Ian Williams - 24-07-2024, 04:29 AM
RE: Constant misfire ?????? - by John Cornforth - 24-07-2024, 08:16 AM
RE: Constant misfire ?????? - by Bob Kneale - 24-07-2024, 10:20 AM
RE: Constant misfire ?????? - by PeterN - 28-07-2024, 01:22 PM
RE: Constant misfire ?????? - by Bluebird7 - 14-08-2024, 04:55 PM
RE: Constant misfire ?????? - by Tony Griffiths - 14-08-2024, 05:11 PM
RE: Constant misfire ?????? - by Nick Salmon - 14-08-2024, 05:15 PM
RE: Constant misfire ?????? - by Bluebird7 - 14-08-2024, 05:16 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 14-08-2024, 06:40 PM
RE: Constant misfire ?????? - by Bluebird7 - 14-08-2024, 10:41 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 15-08-2024, 09:03 AM
RE: Constant misfire ?????? - by NBS - 16-08-2024, 07:59 AM
RE: Constant misfire ?????? - by Bluebird7 - 16-08-2024, 09:57 AM
RE: Constant misfire ?????? - by `Gordonhbm - 16-08-2024, 12:49 PM
RE: Constant misfire ?????? - by Bluebird7 - 16-08-2024, 02:50 PM
RE: Constant misfire ?????? - by Malcolm Parker - 16-08-2024, 03:26 PM
RE: Constant misfire ?????? - by `Gordonhbm - 16-08-2024, 03:46 PM
RE: Constant misfire ?????? - by Steve Jones - 16-08-2024, 03:58 PM
RE: Constant misfire ?????? - by Bluebird7 - 16-08-2024, 04:01 PM
RE: Constant misfire ?????? - by Bluebird7 - 20-08-2024, 04:25 PM
RE: Constant misfire ?????? - by Reckless Rat - 20-08-2024, 05:32 PM
RE: Constant misfire ?????? - by Ivor Hawkins - 20-08-2024, 09:56 PM
RE: Constant misfire ?????? - by David Stepney - 21-08-2024, 09:31 AM
RE: Constant misfire ?????? - by Bluebird7 - 26-08-2024, 04:13 PM
RE: Constant misfire ?????? - by Alan - 26-08-2024, 04:27 PM
RE: Constant misfire ?????? - by Bluebird7 - 26-08-2024, 05:15 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 26-08-2024, 05:15 PM
RE: Constant misfire ?????? - by Bluebird7 - 26-08-2024, 08:33 PM
RE: Constant misfire ?????? - by John Cornforth - 26-08-2024, 10:39 PM
RE: Constant misfire ?????? - by Bluebird7 - 27-08-2024, 08:57 AM
RE: Constant misfire ?????? - by Ivor Hawkins - 27-08-2024, 09:10 AM
RE: Constant misfire ?????? - by Bluebird7 - 27-08-2024, 09:32 AM
RE: Constant misfire ?????? - by Alan - 27-08-2024, 10:05 AM
RE: Constant misfire ?????? - by Ruairidh Dunford - 27-08-2024, 10:54 AM
RE: Constant misfire ?????? - by Bluebird7 - 27-08-2024, 12:10 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 27-08-2024, 12:12 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 27-08-2024, 12:22 PM
RE: Constant misfire ?????? - by Chris KC - 27-08-2024, 12:40 PM
RE: Constant misfire ?????? - by Ruairidh Dunford - 27-08-2024, 01:08 PM
