REIORCEMENT PLATE - YOUR SUGGESTIONS
Should it be as few screws as possible? I suggest that more screws, but very small diameter screws, might be better. I'm thinking of 4 screws per 'leg', so 12 screws in total. Definitely drill pilot holes, and drill right through, use long screws and cut the excess length off with a grinder. Stainless steel screws are often much stronger than ordinary steel.
RE: REIORCEMENT PLATE - YOUR SUGGESTIONS - by andrew34ruby - 05-08-2024, 07:55 AM
