variants of scuttle throttle cross shaft
I realise I don't have a proper chronology in my head for the different throttle cross shafts. I know the Nippy with arc bend, and I have one here which is straight and has the 90 degree bend for the throttle on the N/S. It has no space for any throttle action the central controls (only enough room for the accelerator connection) so I'm presuming its post '32 or whenever the DK4 came in?
I've also seen a cross shaft with a parallel higher section in the middle but not an arc. I'm not sure what that fitted.
How many are there in entirety... and can one back-convert something later for s/wheel centre controls? TIA
variants of scuttle throttle cross shaft - by JonE - 13-07-2024, 02:05 PM
