  • 1 Vote(s) - 4 Average
Tappet Adjustment process
I am trying to start a Ruby after some engine work; the starter is turning over easy and there is spark and fuel at least to the carb but no ignition.
I set the tappets on the bench buit wonder if something is wrong and the fuel is not being sucked through.
What is the best way to set the tappets, do I need to start at TDC or can I dive in anywhere as long as I stick to the rule of 9?
Not sure what else it could be but open to suggestions.
Tappet Adjustment process - by iandecjak - 06-07-2024, 01:00 PM
RE: Tappet Adjustment process - by Robert Leigh - 06-07-2024, 01:12 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 02:02 PM
RE: Tappet Adjustment process - by Alan - 06-07-2024, 02:38 PM
RE: Tappet Adjustment process - by John Cornforth - 06-07-2024, 02:40 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 03:17 PM
RE: Tappet Adjustment process - by John Mason - 06-07-2024, 03:42 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 04:08 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 04:36 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 04:58 PM
RE: Tappet Adjustment process - by Steve Jones - 06-07-2024, 06:28 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 07:30 PM
RE: Tappet Adjustment process - by Alan - 06-07-2024, 07:46 PM
RE: Tappet Adjustment process - by David Stepney - 06-07-2024, 09:34 PM
RE: Tappet Adjustment process - by iandecjak - 06-07-2024, 10:35 PM
RE: Tappet Adjustment process - by Bluebird7 - 06-07-2024, 10:40 PM
RE: Tappet Adjustment process - by Chris KC - 07-07-2024, 05:42 AM
RE: Tappet Adjustment process - by Charles P - 07-07-2024, 09:08 AM
RE: Tappet Adjustment process - by Steve kay - 07-07-2024, 12:20 PM
RE: Tappet Adjustment process - by iandecjak - 07-07-2024, 03:32 PM
RE: Tappet Adjustment process - by Alan - 07-07-2024, 03:51 PM
RE: Tappet Adjustment process - by Hugh Barnes - 07-07-2024, 04:07 PM
RE: Tappet Adjustment process - by John Cornforth - 07-07-2024, 04:40 PM
RE: Tappet Adjustment process - by Tony Press - 07-07-2024, 11:43 PM
