I have just had a set of rear shoes relined by Saftek(posted Monday back Thursday).
I asked for 5mm thick material as the drums are 7.1 internal diameter. Assembly is almost done with new bearings and cams with new springs.
Just need to adjust the cables.
Over many years I have used a variety of lubricants and pastes on the plungers and adjusters with poor results,this time I am using ceramic grease .results to follow,
Looking at the cams looks as though you may have a front and rear,the ones from A7components are clearly marked.
